Inlay has come out
http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=30882
Author:  nam88 [ Fri Jan 28, 2011 7:55 am ]
Post subject:  Inlay has come out
I just took off the strings on my SG and I noticed the inlay on the 12th fret was starting to come off. Its actually completely off now and I have no idea why (its an old guitar from the 80's so could be an age thing). I want to put it back in. I have a wood glue that I could use. Would there be any problems in just gluing it back in?
Author:  Gabby Losch [ Fri Jan 28, 2011 10:47 am ]
Post subject:  Re: Inlay has come out
I'd use epoxy, and maybe mix the epoxy with some ebony dust (assuming your fretboard is ebony).
Author:  peters instruments [ Fri Jan 28, 2011 10:55 am ]
if you're house is pretty exceptionally dry, then the wood might have shrunk enough to pop out the inlay. some older houses can get down into the 20% humidity range in the winter. at least where i am at. epoxy ought to fixe it up right just make sure that it will fit back flush first.
Author:  nam88 [ Fri Jan 28, 2011 8:19 pm ]
Okay sounds like epoxy is the way to go. Anything I should know about using it? Its a rosewood fretboard. And it does fit back in perfectly flush. Any type of epoxy I should use? I am completely new to this.
Author:  alan stassforth [ Fri Jan 28, 2011 10:49 pm ]
Epoxy might be too thick and leave the inlay proud a bit,
and you don't want to sand the inlay,
because this would be a pain, imo.
Also, it might be a sticky mess, if it comes up at da seams.
I would use some medium ca in the cavity,
and not so much that any would squeeze out.
Just enough to hold it in.
Then again,
repair work ain't my strong point!
Author:  Mike Baker [ Fri Jan 28, 2011 11:07 pm ]
Any of those would work. I use good ole' original titebond to glue inlays in, and have never had the slightest problem. If I had to choose something else, I'd use CA.
Author:  nam88 [ Fri Jan 28, 2011 11:09 pm ]
Okay, ill get the ca glue then. Easier for me to get today anyway.
Author:  nam88 [ Sat Jan 29, 2011 7:24 pm ]
Okay it's stuck back in. Thanks for all the help. I screwed it up a bit, wasnt quiet flush so theres a bit sticking up. Dried so quick though. Ah well, still looks okay.
